Hello,
I have a 1985 Toyota Tercel 4WD DLX/Auto wagon. I would love to get cruise control installed in my wagon, but I don't entirely know what parts are necessary to do this. If it makes a difference, I've swapped to a Weber 32/36 progressive carburetor, and I've eliminated almost all vacuum components and all of the emissions. I'm assuming the cruise control would operate from one of my now-available intake manifold vacuum ports.
Thanks for your time. Please let me know if you have cruise control components that would work for my '85!
-Erik
*ISO: Cruise Control parts!*
- eightyfive4WD
- My tercel:: 1985 Tercel 4WD 5 speed wagon
- SirFoxx
Re: *ISO: Cruise Control parts!*
good luck. they are insanely rare for these cars. i had a dealer installed setup on mine that was designed specifically for the tercel, and my roommate had a factory installed kit on his. both were pulled from junkyard cars. both are no longer in our possession.
viewtopic.php?t=16285
1982 4dr Tercel (RIP)
You'd be better off looking for a third party kit.
- eightyfive4WD
Any ideas who made such kits, or what to look for?
- eightyfive4WD
Oh it's definitely a long shot. But I'm putting a feeler out here on the forum just in case.SirFoxx wrote: Mon Jan 03, 2022 9:28 am good luck. they are insanely rare for these cars. i had a dealer installed setup on mine that was designed specifically for the tercel, and my roommate had a factory installed kit on his. both were pulled from junkyard cars. both are no longer in our possession.
after market cruise control kits:
https://www.speedwaymotors.com/ididit-3 ... eb28_2020)
https://www.summitracing.com/search/par ... ntrol-kits
https://www.thecruisecontrolstore.com/
- eightyfive4WD
Nice! Good to know there are other options out there also, if I really feel like spending $$$$ for setups like these.Petros wrote: Sun Jan 09, 2022 6:14 pm after market cruise control kits:
I think for now I will hold off and hope to score a cheap used set of factory equipment but it's definitely good to know that is not where my options end.
There is always the option of adapting another vehicle's cruise control system to work in the Tercel, too.
- Mattel
https://www.youtube.com/watch?v=OKIDgG5Y2yUMy mate Michael has made a camry cruise control fit on to his manual Corolla Alltrac so it looks factory. I imagine it could be done with the Tercel. He discusses it in this video.
There may also be a simple DIY option. My dad once had an old Volvo with an after market air conditioner, for when the A/c kicked on, the installer put in an idle speed adjustment to raise the idle so it would not stall out at idle. fiddling with it on the hwy my dad discovered it could also make a simple cruise control of sorts. it just speed up and held the engine speed to any level you wanted. you could kick it off fast, so it was not too much a hazard (you could also push in the clutch, but the engine would red line). it did not adjust for hills and wind, it just set the throttle at a fixed opening. it would slow on the up hills, and speed up on the down hills. it worked well for open roads in nearly flat terrain, like most of the country.
There used to be simple kits to do this kind of alteration, I also remember seeing one in a J.C. Whitney catalog many ears ago, it was a simple cable with a choke kind of knob on the days, that would kick off if you tapped the brakes. it seems even with out a kit, it would not be too hard to rig something like that from standard hardware.
So you might have an DIY option if you can not adapt an existing one to your Tercel. use with caution.
