Part Number For Aisan Carburetor Accelerator Pump Arm Washer
rivera100
Post by rivera100 »
Hi there,
I rebuilt my Aisan carburetor but there's a washer that broke off. I can't find a part number for a replacement. I've attached a screenshot which shows the washer, spring and clip. This was taken from Robert Walker's (forum member, xirdneh) Aisan carburetor teardown video at around 57:40 minutes into the video. https://www.youtube.com/watch?v=kCzFuPqssfE
The exploded view, also attached, shows the washer circled in red but there is no part number for it. Does anyone happen to know the part number or have a spare?
Thanks,
-Rick
Re: Part Number For Aisan Carburetor Accelerator Pump Arm Washer
it is likely a standard part, like a screw, will not have a part number but will go by size. any washer about the same size should work. as I recall it just holds the top of the spring on the shaft. I think I lost mine too, and just found another thin washer about the same size, been using it for 10 years.
