3A-C fed runablity issues
SynthDesign
Post by SynthDesign »
Working on a Tercel for a local customer/friend. Owner's name is Silas and the Tercel's name is Rhonda.
Rhonda sat for 7 or 8 years with a broken main pulley. We were able to get her started and over to my shop with a handful of driving issues.
I completed the 175k service, timing belt, waterpump ect as well as replaced the clutch/pressureplate and a number of gaskets. I also dumped out the old gas and flushed the fuel system despite her being able to drive on it.
Rhonda fires right up with factory choke working fine. Warms to running temp with no issues. She'll run from 1k to 3k rpms with no issues. Once loaded in gear or higher rpms are attempted, she falls flat.
I've checked the the vacuum lines for propper placement and leaks, adjusted the timing to proper spec and checked for adequate fuel pressure. All are good. I've gone through the FSM and run though the trouble shooting and haven't come up with a reasonable diagnosis. Floatbowl stays at a reasonable level but I'm concerned the 2ndary jet system on the carb isn't running correctly. Before I dig into the carb, I figured I'd post here since I'm wasting time and a bit stumped.
Short video for reference.
https://youtu.be/P6eGQocBMl0
Any thoughts?
2005 Toyota Sienna, work van
85 Toyota MR2 (Blu)
83 Mazda RX-7 Mariah Widebody
Mark
Re: 3A-C fed runablity issues
Post by Mark »
Does the distributor centrifugal advance work? With the vacuum hose(s) disconnected/plugged, rev the engine and make sure the timing advances.
Carb rebuild, it’s always the carb
SynthDesign
Mark wrote: Wed Feb 03, 2021 10:41 pm Does the distributor centrifugal advance work? With the vacuum hose(s) disconnected/plugged, rev the engine and make sure the timing advances.
Distributor advance is working fine.
85 Toyota MR2 (Blu)
ALiveSR5
My tercel:: Was a stock 1985, SR5, 4WD, 6-speed manual, Wagon.
Post by ALiveSR5 »
SynthDesign wrote: Wed Feb 03, 2021 8:57 pm Before I dig into the carb, I figured I'd post here since I'm wasting time and a bit stumped.
Any thoughts?
I swapped an engine that had been sitting for awhile, into mine, and experienced the same kind of issue. Turned out that the stock carb jets were clogged by varnish or gunk from sitting. Cleaned out the jets and it has run fine for over 25 years.
Hope that helps.
No other vehicle that I have ever owned had a heart and soul like my 1985 Tercel SR5 4WD Wagon. :D
Great minds may think alike but it is the doers who see their visions become reality. :?
john
My tercel:: 85 toy tercel 2wd wagon (formerly a 4wd automatic)
Post by john »
Any chance the exhaust is constipated? A plugged up cat can cause a big loss of power under load. john
SynthDesign
The carb was completely filled will varnish and debris.
I scrubbed it out and got it back together in reasonable running order.
85 Toyota MR2 (Blu)
Post by irowiki »
Did it help?
SynthDesign
Seems to be running well enough. I think Silas has put on a maybe a thousand miles so far.
85 Toyota MR2 (Blu)
