Looking for a Steering U-Joint (knuckle)
jimijuma
Post by jimijuma »
Steering is binding. It is the u-joint. Been on the hunt. Will one from an 80s MR2 work? Looks pretty darn similar. Anyone have one lying around they could part with?
jimcrazy
Re: Looking for a Steering U-Joint (knuckle)
Post by jimcrazy »
go down one to part numbers,,,its all ready up on the home page
jimijuma
Post by jimijuma »
jimcrazy wrote: Sat Apr 04, 2020 3:24 pm go down one to part numbers,,,its all ready up on the home page
Saw your thread. Thanks. Looks like I will order that u-joint repair kit, part number 19-1010. That kit is for sale everywhere.
I also spotted this:
https://www.amazon.com/dp/B00NO4NJHU/re ... IEbBW26NNE
Thoughts on that? Says it will work on a 85-88 Tercel.
jimcrazy
Post by jimcrazy »
hard to say if it will work,,the power steering one and the manual steering are different but if its cheap enough may be worth a try
it will not work on the early Tercels, '83-84. the configuration is different, early ones has a spline shaft at one end. it is not that difficult to replace just the u-joint. you can buy just the u-joint and install it. I did a thread on how to replace it.
Here is the instructions: viewtopic.php?f=7&t=9448&p=68623&hilit= ... int#p68623
Here is the part number for the replacement u-joint (about $20 a few years ago): viewtopic.php?f=16&t=10918
if you soak your binding u-joints in motor oil it will hold up a bit longer. eventually it will fall apart, so make sure you get it replaced asap.
The Professor
Post by The Professor »
When I first got my Tercel I had an issue with the steering joint stiffening up mid-corner. Sprayed it with either WD-40 or PB Blaster once, maybe 4 years ago, and have never given it a second thought. The oil took care of the binding in the joint.
Spend a few cents to see if it just needs some lube before you really tear into it.
1975 Subaru SuperStar wagon
1987 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
jimijuma
Post by jimijuma »
I am happy to report that the part I spotted on amazon is a perfect fit. Here is the link again:
As Petro's stated, it will not work on the earlier Tercels. But if you have an '85-'88 T, an amazon account, $32.88, and about 15 mins, your steering can be smooth as silk.
