Sound comes out from a electric relay
Dumindu
Post by Dumindu »
My car is a 1987 Toyota Tercel DX Wagon RHD 1452cc 2bl manual driven car.
There is a clicking sound comes out from the Head Lights relay in the main fuse box.
Head lights are working properly
It is a continuous "tik" "tik" clicking sound. It seems relay contacts and detaches continuously.
Engine start is also poor.
I replaced it with a spare relay. It also emits that noise.
It seems that there is a wiring problem at that relay.
What type of wiring problem could cause such a thing?
kitchman
My tercel:: 1983 2wd tercel hatch back ,1986 SR5
Re: Sound comes out from a electric relay
Post by kitchman »
I would first identify which relay it is. Then I would check the fuse or fuses that supply it with power. Then I would also check what switches or sensors that activate this problem some relay.
Abletobecain
Post by Abletobecain »
Is your battery fully charged with clean contacts and good clean grounds?
Dumindu
Post by Dumindu »
You are correct.
It was the battery that caused the problem. I couldnt off the switch fully. So the clock was working for around 30 hours. It has eaten the battery charge.
After battery was fully charged, now problem was resolved.
Abletobecain
Glad to hear its better, but will it happen again? Is there a problem with your ignition switch that will not allow it to turn off fully, or you just forgot to do so? I forget my lights turned on a lot. I want to add a buzzer or something.
Dumindu
Post by Dumindu »
Ignition switch is usually turned off when remove the key.
But in order to off the interior lights and radio I need to press a button to turn the key an extra slot (last slot) in the ignition switch. ( In other cars I havent seen a such, perhaps only in the 1987 Tercel wagon)
I usually forget to do that.
Abletobecain
That button is on all of the T4WDs as far as I know...it's on all of mine anyway. I forget it sometimes too.
that used to be a common item on japanese cars, I think my old '71 Datsun had one. I completely forget about it because it is just reflex to push on it as I turn the key.
