Alternate transmission mount
JDNightFox
My tercel:: 1986 SR5 / 1987 SR5
Post by JDNightFox » Fri Oct 04, 2019 4:14 pm
Ebay is saying that the Westar EM-8377 transmission mount fits our 4wd transmissions
has anyone tried one out to see if that's true? Or does someone have a transmission mount to compare to the picture? It looks kind of like it but i'm not sure
jimcrazy
Re: Alternate transmission mount
Post by jimcrazy » Sat Oct 05, 2019 6:05 pm
if you get a 4wd one use a fwd one,,cut the side flat bar off the old 4wd one and weld it to the fwd one,,i used the 9 dollar one from rockauto
JDNightFox
Post by JDNightFox » Sun Oct 06, 2019 10:24 am
Interesting
I don't have access to a welder so I won't be able to do that though
The Professor
Post by The Professor » Mon Oct 07, 2019 10:53 am
...if you get a 4wd one use a fwd one,,cut the side flat bar off the old 4wd one and weld it to the fwd one...
I was going to try this, but once I got the 2WD and 4WD mounts side by side, I decided that they have enough differences that cutting and rewelding the mounting tab wasn't going to be a satisfactory solution for me. The two mounts will both have the transmission sitting at different heights above the crossmember and even if you cut and tweak one mounting ear, the geometry of the rest of the "cradle" is still going to be off.
I found a low-mileage replacement 4wd mount (OEM Toyota sticker was still on it!) on a wagon in the junkyard, so never had to come up with a permanent aftermarket solution.
1975 Subaru SuperStar wagon
1984 Subaru Turbo-Traction wagon
1984 Subaru Turbo-Traction hardtop
1987 Subaru RX 3-door
1987.5 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
jimcrazy
Post by jimcrazy » Mon Oct 07, 2019 5:05 pm
i laid the two one on top of the other and they were identical other than the 4wd one was bent over to bolt on
LowBuckCanuck
Post by LowBuckCanuck » Mon Oct 07, 2019 7:25 pm
Interesting
A small cheap-o welder is a worthwhile investment if you like owning old and rare things like tercels.
The Professor
Post by The Professor » Wed Oct 09, 2019 8:12 am
I don't have the 4WD mount that I pulled off to show the differences I saw, but the "U" shape was different enough that even cutting and welding that tab, the other half of the "U" wouldn't be touching the transmission.
