Engine main wire/oil pressure wire connector
Looking for an engine main wire/ oil pressure wire connector and possibly oil pressure s/w too. Parts E and 41 in the diagram picture. Any help would be appreciated!
- BaileySims
Re: Engine main wire/oil pressure wire connector
You may be able to fish out the rubber isolator on top of that connector and solder a new wire to the remaining strands. I've had to make a repair once like that, might have been on the same plug even.
WAGON MAFIA.
Blood, sweat and beers.
Thanks for the advice I was able to get it connector all taken apart without damaging it, and think I’ll be able to fix this one now!BaileySims wrote: Fri Aug 16, 2019 8:17 pm You may be able to fish out the rubber isolator on top of that connector and solder a new wire to the remaining strands. I've had to make a repair once like that, might have been on the same plug even.
