Repair Guides Library of Links
Repair Manuals
Factory Service Manual PDF
Factory Service Manual - New Stuff
Engine
How to Replace a Head Gasket: Petros Method
Replace valve stem seals w/o removing engine
Carburetion
32/36 DGV Weber carbs
Transmission related
Manual Trans Removal and Re-Installation
Suspension
Broken Front Sway Bar
R&R front struts
Rear Differential
Rear Differential Pinion Seal Replacement
Rear Differential - replacing pinion seals
Brakes
Brake Upgrades MR2 Parts Vented Rotors
Heating and Cooling
Replace Heater Core
Interior
New Shifter Boots, Material & Pattern
Engine
Carburetion
Suspension
R&R front struts
Rear Differential
Brakes
Heating and Cooling
Replace Heater Core
Interior
Re: Repair Guides Library of Links
"Like"
still would like to see a" repair video section"
- My tercel:: 1981 Toyota Tercel sr5 hatchback
Does any one has a link or any way to get a repair manual for a 1981 Toyota Tercel hatchback guys
- slimdude85
As far as digitally, I have never found one. I did find a Bentley manual on eBay, though. Here’s a link to one for sale right now:
https://www.ebay.com/itm/1980-1981-1982 ... 0176151221
If there’s something you’re needing to repair sooner than it can come in, I can probably snap a few pics of the pertinent pages for the repair. I just don’t know that I have it in me to scan the whole thing... and the questionable legality of sharing an out-of-print copyrighted work gives me pause as well.
Proverbs 3:25-26
Proverbs 3:25-26
Aguila,
Keegan is in the FB page and may have something, he’s in an early 80s Tercel.
Do you have a link for that broNWMO wrote: Sat Jun 20, 2020 9:24 am Aguila,
Thanks for the info but I am stranded here in central America due to covid I don't have access to purchasing something from ebay, but you think that the 1984 manual is the same for the 81slimdude85 wrote: Fri Jun 19, 2020 8:50 pm As far as digitally, I have never found one. I did find a Bentley manual on eBay, though. Here’s a link to one for sale right now:
I am trying to do a complete cooling system repair, cause I change the head gasket but the vehicle is overheating at a rapid pace
- slimdude85
Yes, it will be the same. The engines remained the same from 1981 to 1987, so the cooling systems will be the same. The only thing I can think of in the cooling system that was different was the radiator/hoses. I recently had to change my radiator, but couldn’t get a replacement for my ‘81. I ended up getting a radiator for an ‘83-‘87 and made my own mounts and brackets. Works great now and no leaks.
Proverbs 3:25-26
Proverbs 3:25-26
Ok thanks one more question have you ever had that issue when you turn on the AC and you keep smelling this strong gas scent but when I open the hood I don't see no leaks or smell anything
- slimdude85
I honestly can’t say that I do, but I removed my a/c system. If it’s a Freon smell and not a gasoline smell, then you may have a leaking evaporator core in the hvac case under the dash. It isn’t any fun to get to, either.
Proverbs 3:25-26
Proverbs 3:25-26
