I was rumbleling around winter today having fun!
Until my clutch cable snap! I try to Jimmy riged it with a rope but it seems to me that the gear dont want to enter went car is running.
The lever on the bell housing feel all right to me
Is there something i miss? Will it works if i get the proper cable? Is there easier alternatives to find cable. Do something with the clutch or Tranny could went wrong?
Broken Clutch Cable
- J Dumarais
- My tercel:: Toyota Tercel 4WD Wagon '86 & Jose 87' Tercel 4WD Wagon
Re: Broken Clutch Cable
Rock Auto lists a replacement cable for our cars, but you might want to get a couple. The first one I bought ended up having the crimped on metal ends backward, and it was cheap enough to not be worth the money or hassle to just buy a 2nd.
- J Dumarais
Thanks for the tip, but Rockauto doen't Worth it so much in Canada with shipping, So i'm still looking for alternative for fixing it.
I've been able to change the length of throttle cables by getting new stainless cable (Wire rope in this case), feeding through the housing, cutting to length, and then welding a fresh barrel on the end, but I don't know how it would work out with the loop on the transmission end. I suppose if you got the equipment you could figure out how to solder it on a new cable, but at that point it's probably much less expensive to order a new cable...
of there is any stretch in the cable it will be difficult/impossible to shift it. the proper cable is very stiff and likely why you have trouble with your temporary repair.
it is perhaps possible to fabricate a workable cable with swaged on cable ends, but likely just buying a replacement, even a used one, is much less troublesome.
