Carrier bearing bushing play - how much is acceptable?
larry mcgrath
Re: Carrier bearing bushing play - how much is acceptable?
Post by larry mcgrath »
These shouldn't flex much at all-----
jimcrazy
Post by jimcrazy »
the drive shaft u-joints are replaceable.use a neapco 1-0430 or a rockford 430-10,direct fit no mods required,check the center of your steady bearing i have had the center bearing holder separate from the rubber,will give you play
jimcrazy
Post by jimcrazy »
the carrier bearings is actually mounted in big squishy rubber mount, usually it can be moved around by hand but it should not feel loose. if the bearing or the u-joints have play, they are bad, but the rubber mount should be pliable and flexible. unless it is clunking around when you accelerate in 4wd, or the rubber mount is shredded, I would not worry about it.
This might help a bit:
viewtopic.php?f=16&t=6459
SynthDesign
Post by SynthDesign »
Little play or deflection ok. Maybe 1mm at the bearing. If the bearing has off spots of clunks it's toast. Carrier bearing rubber bushing should have no more than 7mm deflection up and down.
2005 Toyota Sienna, work van
85 Toyota MR2 (Blu)
83 Mazda RX-7 Mariah Widebody
