ISO: Trans Mount
Tman312
My tercel:: 1985 Tercel 4WD
ISO: Trans Mount
Post by Tman312 »
Looking for a new or good condition manual 4wd transmission rubber mount
The only place I can find the correct part is Autozone, but they have since discontinued it.
Rockauto, Oreillys, etc claim they have it but it is an Auto mount.
OEM Part numbers appreciated too
garyfish
Re: ISO: Trans Mount
Post by garyfish »
part # 12371-15070 ... No Longer Available (NLA) from any U.S. source, including all Toyota dealers, as far as can be determined
here's a recent relevant thread with good info:
viewtopic.php?f=2&t=13273
jimcrazy
Post by jimcrazy »
i use the fwd mount,just have to cut one side off the 4wd mount and weld it back on to the fwd mount.rockauto has the fwd mounts for like 10 bucks
jimcrazy
Post by jimcrazy »
more pics
Like
I likely have several of these rear mounts kicking around in a box somewhere, but they would be well used.
unless your old one is completely trashed, there is a fix I thought of for them if they have just sagged. clean it thoroughly, and and perhaps rough up the void places good with a small wire brush between the rubber mount. Than use wood wedges to get it back to the approx original position, install either RTV or polyurethane adhesive to fill in the void places between the rubber part of the mount. this should stiffen and strengthen the rear mount.
Tman312
Post by Tman312 »
Its so bad that my trans will move completely if I let the clutch out anybit too fast. Usually resulting in a clunk.
jimcrazy - I'll have to look into that, thanks for the info!
