Looks like if you have a 3A-C with manual, you have an ECU:
K-Business
Re: Looks like if you have a 3A-C with manual, you have an ECU:
Chuckle - go back to bed and envision unicorns ...
sort of...it is just a switch box that trips some of the vac operated devices on the induction system. You know, all of those unidentifiable metal can like objects with both wires and vac lines running to them under the hood. One of them controls the fuel/air ratio by allowing bleed air to enter the intake manifold under the carb.
