So after some digging I pulled off my beat up woodruff key and measured the dimensions as best as I could, and then went on the O'Reilly website and matched it up to Dorman part number 595-061
My dimensions (rounding as best as I could): 5mm thickness, 8mm height, 18mm length
I just tapped the Dorman one into place on my engine and it fits! It is about as snug as it can be, the thickness may be slightly less than a metric option but it cost $0.75 and there is barely any rotational slop in the crank pulley.
Thought I'd let you all know!
keywords so other people can search for this later: timing gear, timing set, crankshaft, crank key
Crank Keyway
- Defend_Dingo
- My tercel:: 86 4wd
- BaileySims
Re: Crank Keyway
Hell yes. I'll have that bolt sent out tomorrow.
WAGON MAFIA.
Blood, sweat and beers.
