Water pump bypass leaking
I think I need a new bypass pipe, fluid leaks out as fast as its poured in. The place i took it too said the part is discontinued and I'm not sure where to go from here. I love my 1983 tercel, eager to find a solution.
Re: Water pump bypass leaking
Yeah, the early 3AC's had thin-walled tubes (tended to rust thru) and were replaced with thicker-walled ones in the later cars. I may have a couple around here- where are you located? BTY- welcome aboard!
- slimdude85
- My tercel:: 1981 Toyota Tercel
I may have found a source at https://partsouq.com/en/search/all?q=1626815011 You can also put in your VIN and look through the Toyota catalog, pictures and all. I ordered this myself on Saturday. It was shipped earlier today from Dubai fedex and will be here Thursday.
EDIT: It was only 10.93 to ship, and they shipped it priority “overnight”.
Proverbs 3:25-26
Proverbs 3:25-26
welecome to the forum!
Usually itjust needs a new O-rings (rubber seals), but it is a smiple part to fabricate if indeed the metal is actually corroded away.
either way it is an easy fix, you just need the right part.
I am sure there are lots of spares around this forum, I may have one for you in a box of parts somewhere in my shop, if you can not find one let me know.
- My tercel:: 1983 Toyota Tercel SR5 4WD
I, too, am looking for a bypass pipe, gasket, and orings.
All three parts (gasket, O-rings, bypass tube) are still available from Toyota, I just picked up the set a month or so back.
1975 Subaru SuperStar wagon
1987 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
viewtopic.php?f=4&t=14002&p=105345&hilit=bypass#p105345The Professor wrote: Tue Apr 16, 2019 8:28 am All three parts (gasket, O-rings, bypass tube) are still available from Toyota, I just picked up the set a month or so back.
when you get your replacements, I would advise putting some non-hardening gasket sealer on the o-rings before you install the by-pass tube. I have had the new o-rings get torn when I installed them, putting the sealer on it lubricates and protects the o-rings as you slide them into the fittings.
I have started to lube O-rings and other small rubber seals with Dow Corning Molykote 111, per the recommendation of a trusted friend who owns a reputable repair shop in Portland. This prevents tearing upon installation, as Petros mentioned, as well as protects the rubber seal from oxidation.
