-removed distributor and checked condition of internals for possible accidental damage during storage
-checked all underhood fuses
-replaced engine relay with a known working one
-took voltage readings at the distributor plug (see pic) they seem strange to me, but i dont know what is normal
the old spark on fender test did spark, but weakly a dim orange spark while touching a painted surface with the end of the spark plug and cranking the engine
the car has a stupid starter switch that works independent from the key switch, i dont know why the heck you'd do something like that unless there was something wrong, but me taking apart the engine shouldn't have broke it if it was working before
i should mention that the spark plugs are brand new, and the timing belt was reinstalled correctly
the car DOES have fuel pressure, the first time i tried to start it i forgot the o-rings on the high pressure fuel line and got a geyser
the battery is trash and i have to put it on a charger to test anything, but that shouldnt effect anything either
this car is mostly a fun project for me, its the middle of the friggin winter and im working on it outside now, its bothering me so much that the damn thing isnt done after this long screwing with it, i just want to see the thing run, that and there's no coolant being circulated in the head, so im afraid leaving it out all winter wont be good for it
