Intermittent coolant leak from front of engine
stanrob
My tercel:: Two 1985 Tercel SR5 4WD, Cal. emission controls, one now a parts car (good engine & transmission, still had full power at 310K), another, a low-rust project car, with 307k miles, from Petros
Post by stanrob »
Surprise #28, this one really discouraging: After about the 20th fully-warmed-up trip in this still-new-to-me 85T4D without any sign of coolant leakage, suddenly it dripped about a cup of coolant onto the pavement, then into the receptacle I then placed there. While it was dripping, I laid down to see where the drips came from. Not the radiator, not any of the hoses or hose connections, but somewhere on or near the driver-side front of the engine. It dripped first on other parts, and from there to the pavement. Too much in the way to see the exact leak site. I'm assuming that what finally stopped the drip was depletion of the usual built-up pressure.
I haven't seen a repeat of this yet, but I assume I will when I've done a fully-warmed-up trip.
Has anyone had this experience, and what could or did you do about it?
Re: Intermittent coolant leak from front of engine
water pump seal? nothing else in that area that would leak coolant.
