NOT FOR SALE at this time. It is now my only spare, I sold my other spare transmission.
Original post:
$250 for front trans-axle(4.1) clutch housing, + transmission & transfer case, will not break these apart to sell pieces.
$100 for the matching rear differential (4.1) still in it's axle housing, the axles are gone. This can sell separately.
These came from an '84 SR5 with about 125K miles on it.
However, I found out they are 4.1 ratio (not 3.71 expected for the model year)
by counting the teeth in the front diff.
2 gears have 10 teeth, 2 more have 16, and the big ring gear has 41.
The donor car had a blown engine, I was still able to drive it around a few blocks,
all gears worked fine, and shifted in and out of 4wd without getting stuck in 4wd.
The engine was so noisy I could not say if the gears were making any noises, or not.
Located near Portland Oregon.
is best to email me. mrdance123@hotmail.com
I will not see private messages until I log in here again.
Manual Transmission and rear differential (4.1)
- My tercel:: 84 and 85 4wd wagons
Re: 2 Manual Transmissions, $250, 1 rear differential $100
Here is the transmission out of the SR5 T4 with about 125K miles that blew engine, parted out.
I'd be interested in taking a look at them sometime this winter. Maybe December or January 2018 when time works out. That is if they're still available.
2005 Toyota Sienna, work van
85 Toyota MR2 (Blu)
83 Mazda RX-7 Mariah Widebody
85 Toyota MR2 (Blu)
that aluminum shift fork tells me its 85-88 tranny
diff that that tranny was attached to would be 4.1 gear ratio
