https://www.youtube.com/watch?v=zK74GLDrXW0I can't recall to many members here fitting a 4age. There is this one on youtube.
Main issues tend to relate to exhaust headers needing to be fabricated and fuel injection system / ecu wiring. There are some write ups on here if you do some searchs. I definatly don't remember anyone in California going through this as I believe emmisions might be a problem?
4AGE in SoCal!!
- Mattel
Re: 4AGE in SoCal!!
Re: 4AGE in SoCal!!
it has been done a number of times, there are threads on the topic. that engine is a good option, it is all bolt in conversion, except the ex header, need a custom one. the other is to work out the wiring to go to EFI. you will need to run high pressure fuel lines as well. a lot of details need to be worked out, but nothing too hard (there is just a lot of them to figure out)
there are several threads on the topic.
