Hey there,
I'm looking to get my clutch and front axles done aswell as whatever work in the same immidiate area. My cv leak comes from where it actually meets the trans, the boots are not leaking but it does have a fairly steady leak out of what I presume is a cv axle seal??
The clutch has been rough since I bought it, I have messed with cable and height adjustments, I have about 5-6 teeth on the pawl still, however the clutch is still slipping often and chatters aswell as being very very stiff pedal feel.
I am looking for answers as to whether or not I should order parts myself to be confident in it being he right parts or should I hand the car over hoping that a reputable shop can achieve all I would like done.
I would like to do the clutch job myself but just do not have the space or clean working area for that at the moment and thought I would get the axles aswell as the seals done well I'm at it.
If bringing in my own parts what would be a good start to look for?
Car is a 1987 tercel 4wd manual trans
What info to tell shop before dropping off terc
- My tercel:: 1987 tercel 4wd sr5
Re: What info to tell shop before dropping off terc
Doing this yourself would likely save you $500-600. even if you have to buy tools and rent a shop to do it. if you buy your own parts get either Japanese or USA made parts.
Replace both axles seals, and also your engine rear main seal when you have the trans/clutch out of it. You might also consider replacing the selector level seal on the side of the trans and the rear trans seal (though both of those can be reached with it in the car).
Clutch chatter is almost certainly means it will be going out soon. Might have oil leaking on it it, so check for any sources of motor oil. Might look closely at valve cover gasket (especially that big half moon plug at the back), that is an easy fix you can do yourself.
