Automatic tercel too slow
I have a 1986 tercel (with 55,000 original kms!) with a 3 speed auto and on the highway at 90kms/hr (55mph) the rpms are through the roof. Tried slightly larger tires made very little difference anyone tried swapping the ring and pinions? Maybe from an earlier model that doesn't have 4.10 gears? Any relevant info appreciated.
Re: Automatic tercel too slow
Convert it to M/T- did it to my '87 T4 (gonna need a donor car 'tho.)
Ben,
What is "through the roof" ? My 85' M/T runs near 2,800 rpm at 55 mph. After a year of driving and getting used to the 1.5L, I don't think twice about running 70 mph, even though the engine is turning 3,500 rpm. I do have larger wheels/tires I am getting ready to put on, but that's more about comfort and aesthetics (since my mini-lift) than engine speed.
- splatterdog
Yep, conversion. If I remember right, the auto had it's own unique ratio. 195/70r14 tires shave off about 200 rpm's.
this is common with auto trans, no overdrive gear and it uses fairly low final drive. larger tires are the only thing to try. If you change out diff, the easiest thing to do is to change out the whole third member and front diff assembly, with ones from the '83-84 manual trans, (3.73:1) .
make sure the engine is in good tune, set your spark timing at 12 deg btdc (rather than the factory 5 deg), and live with it. I drove an auto trans tercel half way across the country, the long open stretches of SW desert seem rather slow at 70 mph, but that was about all it could do. You cojuld also add sound deadening insulation under the carpet and on the firewall.
if it comes time for an new engine, you might go for a 4ac, easy swap, and more hp. gives more power.
Bore and Stroke Increase should get you going! There's a dude who did so to his green T4wd on YouTube and he calls it THE GENERAL. Check it out!
K-Business
that would be forum member Synth. He has lots of threads on his building (and rebuilding) of The General on this forum.
