85 won't start
Nwtercel1
85 won't start
Post by Nwtercel1 »
I left town for 5 days and when I returned home I went to start my car and it will not start
Battery is not dead it will turn over fine it just won't fire
Any ideas I should try?
Thanks!
Re: 85 won't start
I would remove top of air filter housing and drop a couple of tablespoons of gas down carb throat. Try starting. If it fires up and dies I would look at fuel supply stuff. If it does not fire at all look at ignition stuff
Nwtercel1
Re: 85 won't start
Post by Nwtercel1 »
Must be a ignition problem
Poured fuel in the card didn't work
If I move the throttle I can see fuel squirt in the carb so it must be getting enough gas
Re: 85 won't start
Post by irowiki »
Does it sound like it is turning over faster than usual?
Nwtercel1
Re: 85 won't start
Post by Nwtercel1 »
It sounds normal when turning over
Everything appears good just won't fire up
Maybe I should try some starting fluid?
Nwtercel1
Re: 85 won't start
Post by Nwtercel1 »
I know that won't fix the problem but maybe it will get it going and give me some ideas of if it runs good or not
TracDoc
My tercel:: 1985 Deluxe
Re: 85 won't start
Post by TracDoc »
I would try starting fluid first and if that did not work I would check the engine/ignition fuses/fuseable links/relays/ etc. After that, I would pull a couple of spark plug wires and check for a spark at each one. If I did not get a spark at the first wire I tried.
