I just received my grandpa’s old Bravada, and am sadly going to sell the Tercel
There’s an oil leak that I’m 90% sure is coming from the oil pan gasket, which apparently is a p.i.t.a. to replace.
It runs and drives great, however.
Pros/Things I’ve done or had done to it since 2014:
New front axles
New front wheel bearings!
New power steering assembly
New alternator
New battery
New starter
New speakers
New ignition coil (iirc)
New water pump and hoses
New master fuses
New E3 spark plugs and good wires
Degreased engine
Extra little parts
Cons:
Driver side window doesn't roll down, the gripping part of the assembly is twerked out.
The oil leak, which you will need to fix because it’s pretty crappy.
Muffler has severed from the pipe and is really just hanging there.
Left swapped fender has an ugly paint job.
Some rust & dents.
Ripped seat.
I made a quick wiring fix near the battery that will have to be done better and safer. Should only take $5 and 10 minutes.
Left turn light cover is broken; the light works fine.
$1300
Please email me @ slearn2@gmail.com or text 1-503-750-5286
