Are 88-92 all-trac corolla springs the same??
Re: Are 88-92 all-trac corolla springs the same??
all of the all-trac corolla springs should be the same, be aware that there are also all-trac Camry and Previa Vans as well, these would be different.
yes, the stock upper front spring seats (or "hats") are smaller dia, the corolla all-trac springs need a larger upper seat that you install on the top of the new spring, but you still use the tercel upper strut mount on top of the spring seat.
