noisy power steering pump.
Hi all
I'm pretty sure the Corolla all trac power steering is similar to the tercel so thought I would ask here, I'm hearing a loud whirring noise from my power steering unit when I turn the wheel a little especially when its cold. it smells a little bit like burning (that could be a little bit of oil leak on the manifold though) the fluid seems a little milky in colour but doesn't have seem to have leaked out. Drive belt seems ok. I'm wondering if the bearings in the power steer pump are shot or something? any ideas? or am I missing something? cheers
Re: noisy power steering pump.
mine was whirring until warm recently
added some auto tranny fluid and it shut up
I have almost 400k miles on my power steering pump, several years ago it started making the same noise. I figured it was likely about to fail, so I keep driving it since I had a spare.
I put in fresh AFT to see if it made a difference, and the noise went away. I am still driving on the original power steering pump, with only an occasional ATF top up.
helipilot77
My tercel:: 1984 SR5 wagon
Post by helipilot77 »
That usually means there is air in the system. If you have a mighty vac try sucking out the old ATF from the reservoir and filling it with new. Also try turning the wheel from lock to lock several times with the engine running to try to bleed any air bubbles out.
. / TOYOTA
./_| |/|/ |]
Hi Guys, Thanks, I realised now that my power steering lid/dipstick is from a later wrecked car and although it was saying full on the dipstick it might have been incorrect for the reservoir so Have topped it right up and lock to lock a few times had some bubbles come out of the fluid so I hope it is OK. Recently replaced the factory metal sunroof with a glass one and been making a few other improvements - am about to install a strut bar and a later interior. Cheers - Matt
lannvouivre
My tercel:: 2006 Pontiac Vibe
Post by lannvouivre »
It's probably fine. We ran the Impala's fluid pretty low for weeks before adding fluid, twice, and it was ok. I'm sure a Toyota-engineered pump will forgive your abuse well enough.
thanks just did 500kms on it since and only a little noisy on full lock but it's always been like that for the last 50,000kms
