WTB passenger side front turn signal lens 85 sr5
coelement777
My tercel:: 1985 tercel 4wd 6spd
Post by coelement777 »
I just picked up a 85 4wd sr5 tercel wagon. She needs a new passenger side front turn signal to pass inspection and I can't find one. If anyone has one for sale im willing to buy either the lens cover or the whole assembly. I can pick it up if you are in the Denver area, otherwise it would need to be shipped.
Thanks everyone.
Re: WTB passenger side front turn signal lens 85 sr5
they make lens repair kits, they sell them in the autoparts stores. It comes with some squares of thin colored lens material and glue. I have used them with good results if the indicator is punctured or cracked. If it is completely shattered, there is also the plastic colored tape they sell for the same reason. meets most states requirements, though your inspection requirements might be different.
BTW, the indicator lights are under the bumper down low, the corner light next to the head light is just a marker light. Not a turn signal indicator. Please clarify exactly what light you need, or post a picture of the damaged one perhaps.
Just want to confirm which light, the actual indicator light under the bumper is just a simple rectangle and you can likely adapt something similar from a trailer supply or auto parts store. the corner marker light has to be replaced as a complete assembly because the lens is one peice with the housing, if it can not be patched or repaired the whole assembly has to be replaced.
coelement777
Thanks I need the marker light. I just bought the car and it's completely gone, previous owner broke it and threw it away and never got around to replacing it. My mechanic says it will need to be replaced to pass inspection.
