Both of my sun visors have broken at the plastic part that has two screws holding it onto the ceiling, that the arm goes through. If anyone has a couple extra, one for driver and passenger side, I'd love to buy them. Or if anyone knows where I may purchase them, let me know. I'm way out down by Astoria, OR, so there aren't any salvage yards within easy distance that have a 1985 Tercel SR5 (dark blue) sitting in them. I'll happily pay any shipping costs as well.
And thoughts on rear exhaust pipe and muffler? My muffler has a significant hole in it.
How about a 4AC engine? My understanding is that I should be able to switch out my 3AC for 4AC, no problem?
Thanks for any help in advance.
ISO: Sun Visors
- nessanater
- My tercel:: 1985 Toyota Tercel 4WD SR5, all stock except for wheels, steering wheel and front splash shield
Re: ISO: Sun Visors
the 4ac engine swap is straight forward, but you have to swap a lot of parts over from the 3ac. almost all of the external parts (mounts, water pump, oil pan, intake/exhasut, etc) has to be switched as well as the flywheel. Everything will bolt up, but it is a job bigger than just doing an engine change.
I might have some visors, I will check over the week end.
Go to any muffler shop to get the exhaust fixed, it does not have to have a toyota muffler. better get it fixed soon, it will allow exhaust into the car, and will also leave corrosive deposits all under the car causing it to rust out faster.
- nessanater
Re: ISO: Sun Visors
Awesome, thanks for the info. I've checked prices for the muffler and rear pipe at a few places. Seemed pretty cheap, sounds like I need to move ahead sooner rather than later.
Engine is just a long term pipe dream. Should probably worry more about my leaking head gasket for the moment.
Re: ISO: Sun Visors
@ nessanater -
When you do the exhaust system - take the time and spend a few bucks and clean, then spray and allow to cure the whole installation with RustOleum's Hi-Temp (BBQ) paint. It saves mucho external rust - and with nothing to flake into your face when under the car later on.
I did Goldie's in 2012 and it is just pristine to this day.
Re: ISO: Sun Visors
a head gasket replacement can be done in 4 hours with $30 worth of parts. Replacing the engine is at least an all day project, more like two days, and much more costly.
