Restricter pin? problem..
Well I got a 85' 4wd really nice condition and today i was changing the fluid front to rear and took i guess its the restrictor
Re: Restricter pin? problem..
your post got cut off in mid sentence so can only guess what you did
i am figuring you removed the reverse pin (19mm) on lower right side of tranny thinking it was an oil drain plug.
you will need to shine a light in the hole to make sure the fork is down and centered on hole
then you can put the pin in
he made another post, he got the pin back in. all is well.
