Top of image going to front of car, bottom of image is fuel tank.
Leftmost line: fuel pickup. *the tank is still full on the Tercel, so it's possible that this is actually the return line and I don't know it yet*
Middle line: fuel return.
Rightmost line that loops back: emissions line.
You can get enough space to access the tank end of the hoses by loosening the left strap bolt and the right strap bolt as far as you dare. If you lift the back end enough to get your forearm braced against the tank, you can push the tank back up with ease even when it's full.
