Ac/heater vents
4wdEconoBox
My tercel:: 1985 Toyota Tercel SR5 4WD
Ac/heater vents
Post by 4wdEconoBox »
I need the driver's side and passenger side heater vents in either black or brown, anyone have any?!
Re: Ac/heater vents
Are threse the approx. 3 x2 adjustable flaps things in the dash? I have two sets. One black. But they are shaped slightly different (early vs late models)
Re: Ac/heater vents
both early and late style vents swap between all years, the only difference is the late style have a wheel that opens/closes that particular vent. i can't remember if the old ones cannot be closed or if you can adjust them all the way in one direction to close them.
i always have a hell of a time removing these things. there are some tiny plastic clips that are very easy to break.
Re: Ac/heater vents
I have not been able to get them out without cutting the dash up (parts cars)
4wdEconoBox
Re: Ac/heater vents
I've found it easy to start on the top left corner with a small screwdriver working around the top until those clips let free, then it'll slide out. It's not too terrible once you get a feel for it, but yeah those are the ones I need, how much you want for them xirdneh?
Re: Ac/heater vents
Just cover shipping.will look for them Tues eve
Re: Ac/heater vents
the plastic gets brittle as it ages. I found it helps to use lots of Armorall as a lubricant (silicone spray might also work), and warm it carefully with a heat gun, than it comes out with less risk of breaking it.
