Airtex 3A1213
looks just like original
if your only getting 1 or 2 speeds out of 4 on your blower
remove
plastic shroud around radio (4 sheetmetal screws) makes it easier to get at glove compartment bolt
plastic speaker cover on right side of glove box (2 sheetmetal screws)
glove compartment (2 10 mm bolts)
two pieces of black plastic vent (2 sheetmetal screws)
the resisitor is near top of heatercore housing
to get plug off you have to depress top center of plug
one small phillips head screw holds resister in place (stubby phillips screwdriver)
Blower (fan) motor resistor
