84 Wenatchee $600
marlinh
84 Wenatchee $600
Post by marlinh »
http://wenatchee.craigslist.org/cto/5201415673.html
Ad Says:
Needs tuneup. Carb clean at least. New carb might do it wonders.
Ive driven it on and off over the past 4 years does great around town.
If you want a highway vehicle this is not what you are looking for.
Shocks are old
Extra low doesn't work in 4wd.
Windshield is cracked
273k on body
burns oil
unknown mileage on third motor thrown at this goat
Someone rescue this?
lucafusi
My tercel:: 1984 Tercel 4WD SR5
Re: 84 Wenatchee $600
Post by lucafusi »
Would love to, even as just a parts car, if I could be assured it'll drive home to Kirkland.. then I'd have to figure out somewhere to put it!
1984 Tercel 4x4 SR5
it is driveabe, should be able to get it home. bet it just needs some vac leaks fixed, or properly routed. I have seen that many times (needs carb...turns out half the vac lines are misrouted or not connected at all). Easy fix either way, should get you home.
