84' SR5
84' SR5
Hey All,
A fellow (not me, yet) installed a rebuilt head on a Tercel only to sheer a fuel pump bolt. He tried to drill it out and it sounds like he drilled some type of hole "along side" the bolt which still hasn't been removed. He figures it will need a new head, but I wanted to hear from folks here. I assume the head is aluminum and the bolt steel, so it would make since for the drill to slide off if not careful. Is there a chance it could be salvaged? what might have been damaged? Repair options: helicoil? JB Weld? some great epoxy?
Without tilt or cruise, I'd have to see how much I liked it on the highway ( I don't mind driving a little slower, would be good for me). Currently 35 miles one way to work five days a week, but there is a possibility I may let my son (just turning 16) drive it starting next summer and I could keep driving my 7th gen Corolla that is turning 300,000 miles on the way home tonight :D Without the fuel pump it's a non-runner, so I am assuming something in the $500-$600 range is fair? Everything else is reported to work well and head had just been gone through by a shop and installed with a new head-gasket. Interior is fantastic, body is straight, but rough, quite a little rust over the fenders.
Any help appreciated.
Re: 84' SR5
Post by irowiki »
Oh, you don't have to drive slower on the highway. My 83 SR5 is completely comfortable doing 70-80. Of course the fuel economy drops like a rock for every MPH above 70 :lol:
Re: 84' SR5
it can be repaired most likely, perhaps without even removing the head. I do not know how you would shear off the fuel pump bolts, they are only 12mm and should only need about 16 ft-lbs or so. If he used too long of a bolt and it bottomed, and kept turing it, that might be a problem (lots of friction on the bolt shank). Usually the if it was just over tightened, there is very little pressure on the threads without a head (unless it is bottomed out with too long a bolt). I have removed lots of broken bolts, sounds like he may have tried to drill out the bolt, and the drill slipped off the steel bolt and went into the softer aluminum.
This is what I would try: clean up the metal chips, spray ATF or penetrating oil on the broken bolt, parhps heat the head with a heat gun or torch. and use a tiny center punch to try and back out the broken bolt, tapping on the broken end with the punch in such a way, off center, so it will back out. This usually works if done carefully, and enough force on the punch. you an also drill a small hole down the center of the bolt (if pssible, centered as best you can), and than step up to the next size drill. and try an "EZ-out" tool to back it out. this also usually works if you can get a hole in the end of the bolt. If not, step up the drill size until it can be backed out. If you have to cut the threads, the easy fix is than to put a thread incert into the hole.
If the hole along side the origial bolt hole messes up the the threads, than putting a thread insert should be done anyway. There are lots of good Youtube videos showing you how to do this, and install a thread insert "Heli-coil" brand is most common.
If it is not badly jammed into the bottom of the hole, the repair can be done in about an hour once you have all the proper tools and a thread insert available and on-hand. Use ATF for cutting fluid when drilling any hole in metal. clean it out well and I like useing lock-tight on the heli-coil so it does not back out when you go to remove the bolt later.
That is not a bad price if the rest of the car is in working condition. the big problem is that you can not test drive it when it is not running. You might find out it needs CV axles, ball joints, wheel bearings, clutch, u-joints, etc. etc until after you get it running and drive it. some of these you can inspect (and you should), but most of it will only become clear after it is driven. You might rig a gallon can to gravity feed fuel to the carb and see if it will run.
good luck.
Re: 84' SR5
Thanks fellas,
The $500-$600 is what I figure it may be worth. He's listed it for $1,000 but indicated there is some play, I can't see going over $600 if everything else looks pretty good. However, they aren't easy to find here in the Midwest, but I've seen a few come across CL. I'll let you know how it works out.
Re: 84' SR5
A pic of the head before installation.
Re: 84' SR5
Hey all,
Here is a pic of the Terc.
4wdEconoBox
My tercel:: 1985 Toyota Tercel SR5 4WD
Re: 84' SR5
Post by 4wdEconoBox »
Something I did when I broke an oil pump bolt is use a tap smaller than the bolt to get it out. First I put a center punch in the center of the bolt to keep the drill bit in place and then used a pretty small bit to drill just a little bit into the bolt, then I put force on the tap while trying to loosen it and it came out just fine and pretty easily. I don't it may help out a little bit, I didn't have any of the proper tools to extract the bolt so I just used what I had on hand haha. I was also a little drunk so and was at the point where I was trying anything haha. But for $500-$600 that would be a steal no matter what the condition from where I'm from(2wd versions in bad shape cost as much as $2000 here in Alabama). Good luck!
lucafusi
My tercel:: 1984 Tercel 4WD SR5
Re: 84' SR5
Post by lucafusi »
irowiki wrote:Oh, you don't have to drive slower on the highway. My 83 SR5 is completely comfortable doing 70-80. Of course the fuel economy drops like a rock for every MPH above 70 :lol:
As an 84SR5er that can't easily get north of 65 without a tailwind, I feel I need to continue tuning up!
1984 Tercel 4x4 SR5
Re: 84' SR5
Post by irowiki »
Well you have to be in 4th for a bit too.
