4wdeconobox,
good job on tail light i got about same results. well worth the effort
it can be done with toothpaste too and most of us should have some around already
about after market headlights
i got the hid kit free thats why i went there
i got
http://www.ebay.com/itm/7x6-H6014-H6052 ... 2c807665fb
for 33 usd free shipping
i like the amber led lights in them but you get what you pay for.
i already wished i woulda got the hella set with e-code but much more $
i have yet to see rain and long term durability from them but visibility grately improved i have yet to be flashed by others in low beam but feels like im on high beam all the time.
an issue i have to look into is that highbeams work but the inside indicator quit.
bulb out or needs resistance?
the fog lamps are ebay too.
http://www.ebay.com/itm/252062094970
$40 usd
they impress me for price super bright
i got the spot ones ,they have flood also
40 usd a pair the provided mount bolted right to a fastener already under bumper in front of turn signal
the pig tail is very thin and my wireing to them 3x the size with second defroster switch and a relay.
i also put two layers of 3000k vinyl film over them this made them a little less bright and fog lamp looking like from 1985 haha
read some were that 3000k color good in rain will have to wait to see as portland has had little for months now not clomplaining
i aimed them two inches lower than low beams at 25ft no one has flashed me at night yet but light up in front of car yellow and then a pure white from hid in front of that they could be aimed to light up very far away if you wanted at least the spots i got. maybe i should of gotten floods for my use
on hind sight i should of thought about front turn signal more as the side markers are very dim as turn signal and need to get a led compatible relay now if any has a sugestion on that ?
i am shopping for upgrade front turn signals now thinking led and they are on all the time and blink off when you turn in harmony with side markers
i have been looking at the12volt ebsite at relay examples and there is one that turns momentary on to solid on
so you wire cornering lights to turn signal switch to look around corners that would be so cool and not expensive considering the dropping price of leds
if they last a year ill get more for rear back up light they would light up an acre when backing up
typing with thumbs sorry for my poor english skilld
