Hi,
Both ports on my washer jar leak. The pumps work though so I am looking for just the rubber bushings. Part numbers I believe are both 85330A although they are denoted with a No. 1 and No. 2. I think they are both the same.
http://toyotapartscatalog.com/toyota/te ... ld-washer/
I have the small filter and it is in good condition
Wanted: washer jar bushings
- My tercel:: 1986 Toyota Tercel Wagon FWD
Re: Wanted: washer jar bushings
I do not think they are obtainable anymore. You'll either need to find a junkyard bottle that doesn't leak, or use an aftermarket pump.
I contacted a couple dealer parts dept and they could order an OEM for less than $5 but it has a 2 week wait time and $10 shipping. I'll wait until I have bigger order or add this to my Pick-n-Pull list
When researching parts numbers, I came across a Beck/Arnley for $1.50. In the picture, the original part is on the right and it's obviously bigger so not sure how the parts could be interchangeable. But I was able to keep the larger diameter of the OEM and use the Beck/Arnley to repair the tear and form a tighter seal. Drip has stopped!
So wait you did find some? Man that would have helped a few years ago.
The dealer here is uncooperative on any parts older than like 1990.
Yes, I provided the Toyota parts number from the diagram as well as the numbers from the pumps. It was the shipping that was hard to justify and locally, the dealer was passing their shipping on to me (so they upcharged me $10)
I have a temporary fix now but I will get the correct part when I tackle cleaning my radiator. pulling everything apart was worth it though: better access to clean that whole corner and the coolant overflow jar is clean (sick soupy mess).
My dealer just flat out says the car is too old to order parts for
That's why I've used Butler Toy in Indy for 10 years!irowiki wrote:My dealer just flat out says the car is too old to order parts for
Others have reported Conicelli in PA and Village in FL are also "mature car" friendly.
None of the many Toy dealers in Metro STL were willing to even LOOK for our vintage parts!
i have two used bushings i aquired after stripping a tercel yesterday
if you want em?
if you want em?
