For sale: CBR600 throttle body components
teranfirbt
Post by teranfirbt »
Hey all, looking to sell the CBR600 throttle body setup that I had on my 3AC:
Comes with:
CBR600 throttles and injectors with redrilled throttle cable hole
Custom 3AC intake adapter with CBR throttle boots
AC/alternator bracket with crank sensor, Ford EDIS coil pack, and '91 Ford Escort plug wires
Custom bolt on 3AC crank sensor wheel
Modified factory 3AC exhaust manifold to close out the intake heater
Custom built vacuum manifold for doing idle control/brake booster/PCV
Uni Filter foam air filter (I'll clean them before I ship...)
Complete wiring harness built for Megasquirt 1 using MS extra code to fire the coil packs
While the parts are all bolt on, it's not a completely bolt on system. You will need to add a high pressure EFI fuel system, extend the factory throttle cable and make a bracket, buy, build, and install a Megasquirt, and probably some other odds and ends I'm not thinking about.
Looking to get $250
