Edit: after I walked away I realized it sounded like problems Dad was having with Pokey, see this thread:
viewtopic.php?f=4&t=10812&hilit=starting
Except he never had running problems after he got Pokey started.
We swapped a carb in because the previous owner thought a carb rebuild was taking the top off, cleaning it out and putting it back together... who knows what he lost but it wouldn't run... also replaced the spark plugs, wires, distributor cap and rotor.
So she'll start right up when cold, and run fine. Most of the time will run fine when warmed up. However I think the thermostat is bad as she never quite gets up to temp.
Sometimes, when warm, and after driving for a bit (10~ minutes) she won't idle anymore unless you keep on the gas, and when she stalls, she won't start back up unless you floor it while cranking, and sometimes won't restart at all until she cools back off. I turned the idle up and it helps sometimes but will idle really rough.
IS the carb we swapped in suspect? Is the lack of a working thermostat screwing with something? Vacuum leak, bad distributor or plugs/wires? The AAP is capped.
I'll try disabling the EGR later.
