camber adjusters
camber adjusters
was digging through my spares to get a set of struts ready to rebuild and have ready to install and discovered the camber adjusters on these out of my 88 parts wagon. had a alignment done in the spring and had to put a smaller bolt in the hole to get it right these should make it easier, first time I have seen them on a tercel.
Re: camber adjusters
in my experience
every tercel 4wd 83-88 has them
every Tercel I have owned have had those kind of adusters. I have owned '83, '84, '85, '86 and '87 Tercel4wd (perhaps 12 or 14 of them including the parts cars) and all of them had that method to adjust the camber. Perhaps you were not looking close enough.
i too have seen them on every tercel i've worked on. they are usually frozen in place, unless the camber was adjusted recently.
