Replace timing belt, water pump, seals & radiator video
https://www.youtube.com/watch?v=fS3bAwwR43w
it could use some improvement.
next time i do this job i will update this
Re: Replace timing belt, water pump, seals & radiator video
Yet another XLNT video from xirdneh - and another sticky!
The torque values for the assorted fasteners are in the FSM in both the Engine section and the Misc. Information section at the end of the FSM.
I would also check https://tercel4wd.com/forums/viewtopic.php?f=3&t=10492 and https://tercel4wd.com/forums/viewtopic.php?f=10&t=10493 for some additional info which could be helpful.
You might also take the opportunity to backflush the heater core using the heater hoses - possibly use the vinegar method on it and the radiator itself - see https://tercel4wd.com/forums/viewtopic.php?f=7&t=10496
Also - take the opportunity before filling the overflow reservoir to remove the inevitable crud at its bottom by using a detergent and repeatedly flushing it. I used a turkey baster to remove the rinses.
