I'm at a crossroads here...
The transmission is out on my tercel, and I don't have the facilities to tackle a rebuild on it currently. It seems to be the input shaft bearing, but I'm not able to get into it to check it out.
Does anyone have a 2wd transmission that they're looking to sell?
And if not, is anyone interested in my tercel?
If I have to let her go I'd love to see her go to someone on the forum. She's got about 250,000 miles. The engine has been running great. The plugs are burning clean. The oil level stays constant. The interior is very clean. The exterior is decent.
She's got a new battery, thermostat, rear struts and springs, and a cv axles in the front. I put in a rebuilt alternator and water pump, and replaced the front passenger wheel bearing.
I don't want to part ways, but I'm living in the city and don't have a good spot to park her up right now...
85 wagon 2wd trans
- My tercel:: 1985 tercel 2wd
Re: 85 wagon 2wd trans
where you at?
5 speed
http://www.car-part.com/cgi-bin/search. ... ge=1&iKey=
4 speed: (I hear you can add the 5th gear to it)
for grins, AT:
5 speed
for grins, AT:
I'm in Oakland,CA. That first one is looking right! Thanks for the heads up! I guess I might be taking a little trip soon.
They have a 4 speed transmission too. Might be worth grabbing it as well if you have cash to spare for a spare transmission you could possibly fix up to be a 5th speed with your broken one.
