Help finding good CV axels, PLEASE
- My tercel:: 1984, 1985
I am needing to replace the front axels in my 1984 Tercel 4WD wagon. I need a decent source for NEW replacements. I would like to do it right the first time. Any help sourcing them would be appreciated. MD
Re: Help finding good CV axels, PLEASE
rockauto.com has some listed from Empire as being new.
Thanks, I just ordered them.
Let us know how they work out (ease of installation & cost).
I've had GSP axles in Goldie for 7 years and app. 21K miles with no probs or noises. Purchased from Rock Auto.
Advance used to carry GSP, but its Tough One private label is actually GSP, I'm told - $70 each.
Autozone also has new ones under its DuraLast label, but for $75 - dunno the manufacturer.
Be sure you install new seals - and check out this link for the proper ones! https://tercel4wd.com/forums/viewtopic.php?f=16&t=6484 FSM has proper installation procedure.
Wow, the driver's side CV axle came off SUPER easy. Except they sent me the wrong axles from Rockauto. Nowhere near the right compressed size. The left side is nowhere near the illustration from the site.
They asked me to send measured pictures, stating correct box/part numbers. But illustrations and measurements way off. It happens, however, I have a car with no axle. The good news is that it was super easy to remove. I feel like I accomplished something by getting the axle off. Confidence builder for sure.
Drivers side
Passenger side
Drivers side
Passenger side
upper one
it looks like a right side axle
lower
looks like a left side axle
lower
That bottom one sure does not look like anything that came out of Goldie!
Check GSP's online catalog for pix (enter make, etc. and pix will appear): http://www.showmetheparts.com/gsp/
Or direct pix of ToughOne axles (aka GSP) from Advance's site:
Left - http://shop.advanceautoparts.com/p/toug ... fragment-1
Right - http://shop.advanceautoparts.com/p/toug ... hTerm=axle
Autozone's site has dimensions, metric & inch:
Left - http://www.autozone.com/autozone/parts/ ... 31_0_78655
Right - http://www.autozone.com/autozone/parts/ ... 31_0_78656
Rockauto.com admits those arent right. Misboxed is what they call them. I returned them with their return label. Hopefully the correct replacements arrive soon. It was a 45 mile round trip to Fed Ex, and a half a day wasted, getting this sorted while I should have been long completed.
Not the greatest experience for the first purchase from Rockauto.
Yes, the parts I got are no doubt way off. Crazy that both parts were wrong though, and in correct part numbered boxes. So goes my luck.ARCHINSTL wrote:That bottom one sure does not look like anything that came out of Goldie!
Don't lose faith in rockauto, I've had generally good luck and only a few bad parts in the year and a half I have been dealing with them, and I think I have spent over $1,000 by now...
I'm with irowiki ,i'v bought a LOT of parts from rockauto with not one screw up ,good place Larry.
I just installed Empi cv axle in my Tercel4wd from rock auto, no fit problems at all. Unfortuatly misboxed items are not unusual, it happens at auto parts stores too. I received a front seal from rockauto, but the wrong one was in the box, I bought another one at OReighly's since was in the middle of the job, same brand, same box, same part number, but correct seal this time. one time I got three different size rings in a piston ring set (all in the same box!) for my Tercel engine. Same thing happened with an oil pump that came from carquest. it is the suppers errors, the retailer can not check every part to verify they actually labeled the box correctly, all the retailers suffer this problem.
That is why when I am buying locally, I always take the part out of the box and inspect it, and if I buy mail order I always take it out with clean hands and inspect it carefully before I try and install it. occasionally I get the wrong part. ONe time in an auto parts store we opened a box for an alternator and it was clearly not the same part. they had another one on the shelf. We opened it and compared them, completely different alternator, even though both had the same part number on the box.
Always double check!
It is not the wrong part aspect that bothers me, it's that the could not expidite the shipping a bit when I have had to get put out, not only in the return, but the slow shipping. That is poor customer service, IMHO.
We screwed up and will get the right parts out to you with a quickness, is the correct way to do business.
While I am waiting for their parts to arrive, I decided to get new ball joints, I chose another company.
- walkersimpson
- My tercel:: 1986 Toyota Tercel SR5, 1984 toyota tercel FWD, 1987 toyota tercel SR5 (shata1)
I also just had this happen to me pulled my old axle and threw the new one in looked right but the splined shaft going into the hub was to long and almost screw up my wheel bearings spent two days trying to pull it out and ended up buying a cv axle puller to the the thing out of there. Send mine back to but good to know that it's just a total screw up on there part but sucks to have to go through the return prosses and have to pay for shipping due to there mess up but hey what can you do. So what are the right ones to buy from rock auto for when I do reorder them
walkersimpson
When you call Rock Auto, mention the other two (2) errors it (OK, its supplier, but regardless) made on another member's EMPI axles and tell the sales person that:
1. Someone must look in the boxes to verify the correct axles are packed.
2. If in error, issue a call tag for their return and ship the correct ones via expedited method.
3. Note the above on your account.
Oddly, my GSP axles came from RA back in '07; wonder why it changed suppliers?
As others have stated, RA is generally easy to work with.
