entrax wrote:I'll take a look at the FSM on how to check on both of those things. it took me a while to understand the choke, and the automatic choke mechanism while reading it last night, but it makes sense so far haha.
the choke valve is pretty simple. carbs use the suction created by the pistons to suck fuel out of the carb jets and air through the air intake. all the choke does is mostly close the valve in the air's path so that the engine is sucking less air and more gas--ta da, a richer mixture, which is necessary when the engine is cold.
the choke is activated by a bi-metallic spring that has a constant 12v going to it. when it's cold, the spring is wound tighter so as to hold the choke valve closed. as the 12v heats the bi-metallic spring, it unwinds and causes the choke valve to slowly open.
so the main things to look for with a choke are to make sure the valve moves freely and the linkage is not stuck (which can happen if it has sat for a long time), that the bi-metallic spring still has the correct resistance (this is in the FSM but i think it's 11-13 ohms), and that the wire going to the choke has 12v when the key is in the 'on' position.
all that being said, don't forget to check the AAP. they seem to be more prone to failure than chokes.
entrax wrote:Also, the rust. There's a lot on this car, especially where that big dent is. I managed to pull out a lot of where the bottom of the quarter panel was squished in, but I have to find something to get in there to bend the rest back out. Rust will be treated with por15 and even though it's not fixing the cancer, it will stop it where it is now.
the plastic trim in the cargo area is easy to remove so it might be best to take it out so you can hammer that rear quarter panel out. it might still be awkward access but take a look and see.
with those huge tires and wheels, if it seems like you're getting crappy mileage remember to account for the difference in tire size. you can use an online tire size calculator to figure out the difference between what your trip meter reads and what you actually drove.
entrax wrote:Good to know that the vacuum diagram is on here. I had a look the under the hood to find the usual toyota vacuum diagram there, but alas, most of it was rubbed off already from age.
i posted a pic of the vac diagram from my canadian '84 manual trans a while back. i have worked on all years of manual trans canadian tercs and the emissions have all been the same so this should work for you.
https://tercel4wd.com/forums/viewtopic.php?f=7&t=2810#p55103
entrax wrote: I am very hesitant to go to mechanics as I believe that learning how to do things is much more valuable, so I hope my questions don't bug you guys too much!
ask away! everyone here is happy to help. some car forums can be full of peanut gallery comments but that's pretty rare here. besides, most mechanics don't want to work, or don't know how to work, on carbs anymore.
entrax wrote:Speaking of oil, the PS fluid I have in there looks golden like oil, but smells like ATF...anyone have an idea what I might have in there?
i have used both ATF and power steering fluid. i have had no problems with either. it is probably a good idea to flush and replace the PS fluid since it has likely not been done for many years but i don't think there's a need to do it sooner than later.
entrax wrote:For timing, would I have more problems setting it to 10BTDC rather than 5?
to pass emissions, yes. put it to 5* for testing and then adjust it back to 10* afterward, if you like. 10* btdc yields peppier performance (relatively speaking) and will not cause any running issues.
entrax wrote:Also, when I start the car in the morning, do I need to pump the pedal? Two days ago I just turned the key without stepping on the gas at all and it took about 4 cranks. Yesterday morning I tried it with half pedal down while starting and it fired up right away, stalled, started well the 2nd time. compression sounds good from cranking, but I haven't yet tested for compression
carb'd engines require you to step on and release the gas pedal before you start it. this both gives the engine some gas to start with and sets the choke valve position. step on and release the pedal once or twice, depending on how cold the engine is but do not hold the pedal down. holding the pedal down does not set the choke, and gives the engine excessive gas which can cause flooding (you would just have to wait 5 minutes before trying to start it again) and is wasteful.
