Combo switch Repairs ?
Social
My tercel:: AL25 1984 4X4 Wagon -AE86 4AGZE-
Post by Social »
Anyone got a loose headlamp switch?
When i indicate due to the switch being old it switches either the parkers or lights off or on..
Its becoming annoying..
A fix would be great..
I was just going to put a rubber band around it to hold it ..But thats not fixing anything
Thanks 8)
AL25 Wagon / AE86 Levin 4agze / Honda CRV.
Re: Combo switch Repairs ?
Post by irowiki »
Junkyard replacement might be your best bet!
if you can not find a replacement it is worth taking it apart to see if it can be repaired. these multi-switches are not difficult to remove and take apart. You pull the steering wheel, and the plastic trim on the steering column, and two connectors and several screws will have it out. If I recall there are several tabs or screws that are easy to remove to open it up. Parts wear out, so if you can fabricat a new contact or even bend it so it makes better contact, stretch or replace worn springs, etc. you can get it to work again. It is worth a try.
Social
Post by Social »
Thats what i wanted to hear Petros.It cant be to much work to fix it IMO.
i will have a look at it soon and if i endevour to fix it i will post some pics of it up dissasembled.
some corolla ae82 indicator switches might fit? might be easier to find at a wreckers.
Social
Post by Social »
FIXED...It was the lower part of the rotate not being glued to the stalk anymore..A touch of glue and bang like new..
Happy days........
Thanks for all the info to everyone who posted above.
