marlinh wrote:You do not need to remove the plate around the rear main. You can pop the seal out using a screwdriver or an actual seal puller. You slide the tool alongside the shaft into the seal and then pry it out at an angle.
Thank you Marlene, you gave me encouragement to actually attack it with a screw driver!
Petros wrote:you will not see the seal by removing the clutch, but the flywheel has to come off too.
Yeah, I had the wife on the other end with a breaker bar and I got the flywheel off. Seemed rusted!
When you install the new one I put grease on the lip of the seal and light oil on the crank (starting with a dry seal will ruin it), and I also like putting some non-hardening form-a-gasket around the outside to kind of "glue" it in place. it is not really necessary, but it has prevented the seal from popping out because of a high crankcase pressure problem (that way you will only have one problem to fix, not that one plus replacing the seals that got blown out.)
Hmm. I installed it before I read this, but I coated the entire seal in motor oil first. Do I need to redo it with glue?
Here it is:
The right side as you see it is not exactly flush, off by maybe 1/32 of an inch. Will that matter?
dlb wrote:i'm personally in favour of retaining the EGR. on a properly functioning engine/carb, it should have no noticeable impact. on the most recent project car, i enabled it and disabled it and didn't notice a difference in power or anything like that. and the exhaust gases lower peak combustion temps which combats predetonation, which is even more important if you like running with the base ignition timing advanced.
I will keep this in mind...
i would replace all the other oil seals while you are at it too, paul--cam, distributor, fuel pump. the VC is easy enough to do in the car so you could leave it until you see if it leaks but i would do the others while the engine is out and they are easier to access.
I have a new fuel pump I'll be installing and I think it included gaskets in the box. One of the gaskets may be broken though... I also have a new valve cover gasket, and a distributor oring gasket. I did not buy a cam seal based off the other thread I started about what to get, but I can before I start the "mini rebuild".
Petros wrote:
You may also have to swap the oil pans so it will fit in the 2nd gen Tercel (depending where the engine came from), if you do I would pull off the #4 connecting rod cap and inspect the bearing. If you do not have to swap the pan than I would not bother unless you suspect some ran it without oil, even briefly. [/img]
There's still oil in there, he drained most of it out before selling it to me. I forgot all about the oil pans, I guess I need to order an oil pan gasket. It came from a tercel sedan first gen so I'll double check to see if they're the same or not.
i'm not sure about tercels but other vehicles i've worked on have required lock-tite on the flywheel bolts so don't forget that when you reinstall it, if it is in fact called for.
Party is an automatic
Perhaps the flex plate is locktited too?
Gottolovem wrote:I won't lie i just want to track this thread with my phone
What about a weber? Some love them and some not so much
Yeah I'm pretty stoked. Overwhelmed, but stoked!
I've heard the webers don't do so good in cold climates, and I have to deal with cold!
So I have another question. Where's a good place to get longer bellhousing bolts so I can mount the engine to my engine stand? 12Mx1.25
