Fresh Horses
Mad_Marx
My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
Re: Fresh Horses
Post by Mad_Marx »
the total bill from the exhaust shop was around $200, that also included the hangers and a couple of vibration isolators (rubber mounts), and welding in the new muffler and cat (I purchased the muffler and cat through Summit for around $150.00). so $350.00-ish for the whole system.
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
At 222,222 miles the original heater core gave up the ghost. Also had a little strut knock from the right front (Monroe Sensi-Trac), and a leaking inner axle seal (I buggered it on the install). Strut was under warranty, did the left side while I was at it, heater core cost me $60.00, the seal was $12.00 (plus 1 qt of MTL $14.00). Should be ready for the next few hundred thousand in a day or two :D
4wdchico
My tercel:: 1985 tercel 4wd
Re: Fresh Horses
Post by 4wdchico »
Mad_Marx wrote:At 222,222 miles the original heater core gave up the ghost. Also had a little strut knock from the right front (Monroe Sensi-Trac), and a leaking inner axle seal (I buggered it on the install). Strut was under warranty, did the left side while I was at it, heater core cost me $60.00, the seal was $12.00 (plus 1 qt of MTL $14.00). Should be ready for the next few hundred thousand in a day or two :D
MTL Redline in a hypoid gear set? MTL is only rated up to GL4. Most hypoid gearset makers require GL5 as a minimum as does the T4wd FSM. That's why I run Redline 75w90 NS in the T4wd manual trans it is designed to work in transaxles like ours. GL4 is not designed to cope with the wiping/shear issues involved win a hypoid gearset.
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
d'oh! guess I've gotta do an expensive servicing. Thanks!
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
Took a few extra hours to take apart all the duct work and wash with a bleach/dish soap mix after finding a mouse house in the AC box. Thanks to sdoan for the Heater Core write up, and 4wdchico for the trans lube correction! Trans and rear diff freshly flushed. Air ducts freshly flushed. Looking forward to breathing a little easier :D
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
Special thanks to Gottalovem, and Florrykitty for the set of factory 13" Pizza Box alloys.
Got the first one back from the wheel shop today. Here's the same wheel before and after the refurb.
Re: Fresh Horses
WOW!
How do they do it? What was the tariff?
Goldie's Daisy wheels are 99% perfect, but am just curious.
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
TSP wash, media blast, machine the outer edges, cleaning up gouges and dings by hand, paint and clear coat. Around $100 per wheel. (A bargain if you consider finding an original 13" alloy in this condition).
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
Got the last wheel back from the shop today, now I have a matched set :)
Re: Fresh Horses
Nice work Mad_Marx. BTW I was hoping you would make a post apocalyptic Tercel police pursuit interceptor that sucks nitros and is the last of the great Japanese 4 cylinders by now - just to go with your name.
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
If I were to have such a car, I'd be waiting for the apocalypse to happen before I roll it out ;)
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
Did some repair work on the center caps. The metal retainer clip ring is held to the cap wit melted plastic mounting pins. Some of them were barely hanging on. I used a little JB Weld to reinforce the attachment points.
