that's a really good idea, peter. i'll have to look at the vacuum diagrams to see if there's a way those might work.
also, hopefully both toyota and these aftermarket valves are the same thread but i have a feeling that toyota used BSPT for these as well as the oil pressure senders.
CO to high for smog check
- My tercel:: 85 toy tercel 2wd wagon (formerly a 4wd automatic)
Re: CO to high for smog check
Good news! My car is once again smog legal in California... even if it is not a completely legal member of Tercel4wd.com (some of you may remember that I replaced my 4wd automatic trany with a 2wd trany a couple years ago; thank you for the privilege of belonging to the group!).
I am grateful for our members advice. I followed much of it and have a super clean running car. I replaced the AAP valve (the old one was not very pliable. I replaced the oxygen sensor (the other was probably original with 290,000 miles). I replaced the TVSV (the old one flunked the boil test).
emission results:
at idle %CO2 was 13.0 now is 10.5
at 2500rpm %CO2 was 13.0 now is 14.2
at idle %02 was 2.8 now is 6.7
at 2500rpm %02 was .4 now is 1.0
at idle HC was 10 now is 10
at 2500 HC was 54 now is 14
at idle CO% was 0.00 now is 0.00
at 2500 CO% was 2.82 now is 0.00
Talk about clean. Glad I actually repaired this without putting in a new cat. Should be good to go for some time.
Thank you again to all! john
emission results:
good job, john. glad to hear you are able to keep your car on the road.
290,000 miles! that's 466, 700 km! wowee. what a testament to the longevity of these cars. awesome.
