Peru , toyota carib 87
Pearson
My tercel:: Carib 87 4wd JDM
Re: Peru , toyota carib 87
Post by Pearson »
Blade did you get the color ?
blade
My tercel:: No tercel. (stolen)
Post by blade »
yes i did it is the same color as the 89 chevy cavalier i cant remeber the number but i have it writin down so i will post it when i can.
terceldude
Post by terceldude »
not sure this is really a Carib... Probably just a re-badged T4wd! :o
K-Business
Pearson
Post by Pearson »
terceldude wrote:not sure this is really a Carib... Probably just a re-badged T4wd! :o
dude its a carib thats what it says on the papers of the car and here in peru some cars comes from japan and here we do the sidedriver change. ( we import cars from japan)
http://s960.photobucket.com/albums/ae89 ... 000864.jpg look at the plate next to the back red light it says CArib 4wd
Careful, Pearson - you are messin' with the Carib Crown Prince..."OMG - the latter is wrong!"
Upon perusing your link - the silver bumpers look a lot better than I would have thought.
Now, that is a serious chain in the last photo!
Pearson
Post by Pearson »
ARCHINSTL wrote:Careful, Pearson - you are messin' with the Carib Crown Prince..."OMG - the latter is wrong!"
Excuse me but i dont get the idea of the frist sentence you wrote, sorry im not a native english speaker.
Yes the silver bumpers look fine for me i was thinking on painting all red but i decided not to, and about the chain .... well you have to take care off your car in a country as mine.
That's one way to make sure your car stays where you put it. :shock:
Pearson
Post by Pearson »
takza wrote:That's one way to make sure your car stays where you put it. :shock:
yes and if you continue seeing the pictures on the gallery you can notice i use another chain in the shifter, that stops the displament of it and makes it imposible to use another gear than reverse while it been used ( the chain ).
Now i can be more relax while im separed from my TOYOTA :lol:
Sorry - I just noticed your March puzzlement over my comment about the "Carib Crown Prince;" it was a sarcastic comment about another member who is quite a student of the "Carib" badge...
Also - I just noticed from one of your other photos - your car has a switch on the floor console to engage 4WD, unlike ours, which have another lever..
Pearson
Post by Pearson »
ARCHINSTL wrote:Sorry - I just noticed your March puzzlement over my comment about the "Carib Crown Prince;" it was a sarcastic comment about another member who is quite a student of the "Carib" badge...
ok i get it.
about the switch it works with a vacuum sistem that actuates over the 4wd sistem. yes i like that sistem cause i think is easier, i´ve a questions when you turn on 4wd to disengage it you have to use reverse? because its the way i use to do it.
Pearson wrote:i´ve a questions when you turn on 4wd to disengage it you have to use reverse? because its the way i use to do it.
Not usually - but sometimes depending on the phase of the moon or the tides or ?, some have had to do this.
Our FSM for North America does not cover the vacuum method of actuating 4WD; I don't think anyone has ever mentioned this before.
Pearson
Post by Pearson »
Im gonna try to take pictures so you can see what im talking maybe im not using the right words for what i want to xpress.
Curious, looking at the interior pics, it appears the heater control panel is not only a bit different, it also is a mirror image of ours. The A/C button, the fan, selector and heat controls are on opposite side from the North American panel. Perhaps this was done because these cars are driven in the southern hemisphere, where everything is upside down.
I love that steering wheel, is that stock? Why couldn't we get that kind of steering wheel here?
I thought usually the push button 4wd selector was done with electric solenoid, that is how it is done on the newer All-trac, and on our MPV 4x4. Also the Honda Civic wagovan 4x4 uses solenoid engagement. These have proven to be reliable but I prefer a simple and reliable lever, nothing to malfunction.
I believe Pearson said the car was originally from Japan and switched to LHD, so perhaps that is the reason for the mirror images you mention - and maybe the JDM cars got the vacuum 4WD switching and we in the wild and wooly rest of the world got the lever system.
Boy, that sounds like a major change of the whole dash, as well as the controls - not like the (relatively) easy swap that BritMobiles did back in the old days!
Pearson
Post by Pearson »
Petros wrote:Curious, looking at the interior pics, it appears the heater control panel is not only a bit different, it also is a mirror image of ours. The A/C button, the fan, selector and heat controls are on opposite side from the North American panel. Perhaps this was done because these cars are driven in the southern hemisphere, where everything is upside down.
Yes the control are the same but un a mirror view, about the wheel is stock i also like it thats why i have not changed.
In one of the pictures im uploding i think number 1036 you can see that kind of can that is upside the brake master thats the vaccum i was talking about thats coneccted to the gearbox by 2 hoses.
Another curious thing is that the brake master is place in passenger side and is connected through a metal bar that goes to the driver side so you can aply brakes again thats because in japan they drive oposite side.
Another one in picture 1041 you can see the hydraulic clutch, it was a mechanical one i mean it used cable to action it but i changed it for a hydraulic one.
3 months ago i did a general overhaul of the motor i apologize because i have no pictures of the process but i was flying by that time os i couldnt be in the repair shop. ( im a pilot )
Also in th pictures you can see my 70% tinted windows i did it last week also painted the border of the windows to give it a special look.
Also i painted my rims ok ok some might say its ricer but i think it looks nice and cost very cheap like 5 bucks to do it so its ok.
Does it look nice i mean the colors i acept advices.
And again i feel excited about talking our cars.
