What comes to my thought too is the pressure being too high and the float just works in too much which could feel like a low gas! It says 4-7 psi on the package so it vary between the 4 and 7, I know the weber 32/36 needs a steady 3 psi according to weber spec! So the regulator could be an idea!
The package mention 32G/H so it might be a little low there too, as you mention
40GPH is recommended for a Weber 32/36 run hard (seriously whatever that means) and 34GPH for daily driven." according to the guys at Carb Connection in Kirkland WA
, when I drove slow it felt alright and when I slam it it seems to gradually burp but then again the pump start to make a bit of a noise at the same time, and seem fine at the beginning, I am very low on gas! I'm gonna have to go by elimination! While filling this post I also phone napa and order and adjustable fuel pressure regulator for 25$ in tomorrow! So I'll knock 2 birds with one rock, I'll make the gas needle move at least and put that regulator in, so if fails again the guys at Carb connection are probably right cause I drive hard! Will see! Can't think of anything else, it's pretty basic got to find the right spec I believe!
(Re-edit) Dunno if cause I use the return line of the weber now, it could cause that I need a different float adjustment! Really doubt it! Could it make a difference?
Other things I know the stock pump delivers 4.6 to 6 psi, which could be the pulsation noticed! Now I'm 4 to 7 psi quite a bigger margin(double) which might be the intermittent burp! The only thing I can't find so far is how much GPH the stock pump delivers, anyone knows?
And found this very interesting article:
http://www.chevyhiperformance.com/techa ... ewall.html enjoy!
