ISO 6 speed transmission
Re: ISO 6 speed transmission
Post by irowiki »
Yes
Defend_Dingo
My tercel:: 86 4wd
Post by Defend_Dingo »
Excellent!! I'll try to make it out there next Saturday then. How does the titling work in New Mexico? My current one had a SD title which didn't require a notarized signature which was strange but instead it required a few other things.
Defend_Dingo
My tercel:: 86 4wd
Also could you check the tires to make sure they're good to be towed on
It's a long 350 mile drive back
Post by irowiki »
So flat towing or dolly towing?
And you're coming out 100% for sure?
Defend_Dingo
My tercel:: 86 4wd
Yes as long as my weekend stays open with no surprises
And it will be a dolly, that's what I used with the last one
Post by irowiki »
OK, if it is a dolly, we may have to disconnect the drive axle to the rear diff. Not done it before but shouldn't be hard.
I will check the two tires that hold air to see how they look.
You could bring two of your good tires.... and your spare
The car has a spare I bought from somewhere else but I have forgotten if it was any good.
Defend_Dingo
My tercel:: 86 4wd
Would that affect it if it's not in 4wd? Or is the driveshaft always engaged
Post by irowiki »
Dan has towed many 4WD Tercels on a dolly in neutral and FWD mode, and it works fine, the problem here is with the seized up transmission, it may not want to do that...especially if it seized in 4WD mode! Won't know until we try!
Defend_Dingo
My tercel:: 86 4wd
Oh I see
That will be the fun part
Post by irowiki »
Or for all we know, it'll spin the transfer case but if it's out of fluid or there's metal pieces in there, it could seize partway home.
So yeah.
Defend_Dingo
My tercel:: 86 4wd
On second thought let's disconnect the driveshaft
Defend_Dingo
My tercel:: 86 4wd
Okay, so I'm gonna pull off the two 29" all terrains from mine and I'll swap those onto the rear axle. If you could get the rear driveshaft off for me if you have spare time this week that would be great.
Trying to cover all the bases so this goes smoothly. lol
And if the title needs to be notarized could you get that done too
Post by irowiki »
29 inch?
Never heard of titles needing notarized here.
Apparently if it isn't stuck in 4wd we don't need to disconnect the drive shaft.
viewtopic.php?f=4&t=11712
Friend will be over tomorrow to move my trailer then we'll start working on her.
Defend_Dingo
My tercel:: 86 4wd
Yeah the previous owner put on some nice juicy off road tires on mine
And awesome! Thanks
AZ does notarized signatures so I wouldn't know about other states. Just making sure :D
Post by irowiki »
29 inch tires will fit on a tercel? I can't see it...
We can do a bill of sale and all that Jazz too.
