So here goes, 84 SR5 4WD ive been bringing back from the dead. Previous owner neglected for 20 years. Unbelievable compression is still great. So clutch needed to be changed. It was my first time and it was less than fun. Had the flywheel machined all seals and bearings replaced AISIN clutch (CKT-010) KOYO bearings I think. Wrestled the somnbish back into her home and torqued to spec.
So I finally get to test drive and I'm experiencing slip at high RPMs....womp womp womp. Followed the freeplay adjustment procedure and verified the arm on the bell housing isn't applying pressure on the plate. I really don't want to have to remove this $%&&%$ thing again.
So questions
1. Could they have machined the flywheel surface too much so that the clutch pressure plate wouldn't apply enough pressure?
2. It is fine to 3K rpms but slips with more throttle, could it be breaking in for the 500 advertised miles? Reason I ask is that ive found almost everyone else has no slip during break in
3. Potential fluid or grease on disk or plate or flywheel...Used minimal amounts of lube on the points required in the FSM. I'm thinking bad thoughts like drilling a plug hole out on top of the bell housing and dousing the thing with two cans of brake cleaner...
Any and all ideas and opinions would be much appreciated! First post so sorry if I'm noobin
