I was driving up a hill at 45 and my rpm gauge dropped to zero and I lost all throttle now I can't get it to start
Any ideas where I should start
I turns over and try's to start
Lost throttle & rpms when driving won't start
Re: Lost throttle & rpms when driving won't start
Is distributor loose?
Only time one of mine did something like that the timing belt broke. Engine cranked over much faster than normal but never fired.
i have had that happen twice to me over the years,something in the distributor gave up,,swaped in another distributor and carried on,,never brothered to test to see what gave up as I have a half dozen spares
Same here- did you check for spark?
Thanks everyone
It does appear to be distributor and I am in the process of finding another to swap in
Timing belt may have lost some teeth
check the timing belt first, it will not spark with a broken timing belt because the cam is not turning the distributor.
if timing belt is okay, verify cam (or rotor in distributor) is turning when you crank it (to eliminate any mechanical failure in the system). even the distributor shaft can fail. so if everything mechanically is good, than swap out distributor.
if cam is not turning, a new distributor will not help.
Will do I will report back
Thanks!
Thanks!
Turned out to be distributor
Back on the road
Back on the road
